Aspect Ratio
COW Forums : DVD Authoring
Thayalan Paramasawam
Aspect Ratio
on Nov 14, 2012 at 9:15:04 am
Hi Sir,
Some times i use tmpegenc dvd authoring for author dvd,What is defrend pixel 12:11(4:3) and display 4:3.Before i start to author the dvd which render by svp 11,i must set the aspect ratio.
Thank You
Daniel Ludwig
Re: Aspect Ratio
on Nov 16, 2012 at 5:52:20 am
hey thayalan,
could you please explain what system you are working with. are you talking about PAL or NTSC.
there are different aspec-ratios and pixel-sizes at both of them.
PAL is 720x576, NTSC is 720x480 with different aspec-ratios at 4:3 or 16:9.
cheers
danny
Re: Aspect Ratio
on Nov 16, 2012 at 8:20:55 am
Hi sir,
i am using tmpegenc dvd authoring,so i want to make dvd pal 4:3.
i post the setting.
Thank You
Daniel Ludwig
Re: Aspect Ratio
on Nov 16, 2012 at 9:30:24 pm
Thayalan,
your input video is 720x576 (aspec-ratio 12:11) or 768x576 (aspec-ratio 4:3)
cheers
danny
Re: Aspect Ratio
on Nov 17, 2012 at 12:27:00 am
Hi good morning sir,
My Video stream is 720x576 (4:3)
Thank You
