Need to get info off a home made DVD!
COW Forums : DVD Authoring
Phil LeBeau
on Sep 29, 2012 at 1:49:29 am
I am doing a memorial video for a friend. They have a dvd that has vhs footage on it.
I need to get part of the video off the dvd (with audio) and put it on a new dvd with a photo montage.
I think it was done with a Sony DVD recorder. Probably one of those VHS to DVD recorders.
The folder looks like it is locked and I cant see any files in the DVD.
Do you know how I can get around this? I have attached a pic of what the folder looks like.
Thanks for your help.
I have an IMAC with 10.6.8 and I was going to use premiere to edit.
Cant even take a screen shot with DVD player open.... geez!
Phil LeBeau
http://www.phillebeau.com
eric pautsch
Re: Need to get info off a home made DVD!
on Sep 29, 2012 at 2:56:49 am
Mpeg stream clip is what you use
Phil LeBeau
on Sep 29, 2012 at 3:25:58 am
I think that will do it. I had to open stream clip first and then pick Open DVD.
I was looking for files on the dvd but nothing was showing up. Thanks for the help!
Phil LeBeau
Daniel Ludwig
on Sep 29, 2012 at 5:10:49 pm
Phil,
if the DVD was created using one of these DVD-Recoder (consumers) and the disk havenĀ“t been finalized you wont be able to see anything on your computer.
no data on disc, neither any video within the software-player.
the disc needs to be finalized first, too if you would like to use streamclip.
cheers
danny
