DVD Authoring DVDLab Pro2
COW Forums : DVD Authoring
Rocio Aranda
on Aug 28, 2012 at 2:40:56 pm
Hello everyone!
My apologize in advance because my English.
I hope that my explication is clear.
I need advanced help with DVDLab Pro2. So I hope to find any solution thanks to your suggestions.
I am working in a project with two movies and I need to block each movie and each chapter through a keypad.
The structure is:
Main menu with both two movies so to watch them first the viewer needs to enter an access code (keypad).
Also from each movie (it has 5 chapters) it's necessary an access code to play each chapter.
So, could anyone, please, help me to find a solution for it?
Thank you.
Regards.
Rocio Aranda
Rocio Aranda
Re: DVD Authoring DVDLab Pro2
on Aug 29, 2012 at 3:26:19 pm
New doubt!
What can I do?
I imported a .box component with my keypad. Now I need to open it to change the access code. When I try to open the menu to appear a window: " Failed to create empty document".
I don't understand because with the others Keypads I don't have any problem.
Any suggestion?
Thank you in advance!
Regards
