TV flicker on DVD after aparently doing everything right
COW Forums : DVD Authoring
Ryan Garcia
on Jun 16, 2012 at 10:24:26 pm
Good day.
I recently finished a dvd project. I wanted it PAL widescreen, this is what I did:
-started sony vegas project with the settings: DVD/PAL 16:9 with VĂ­deo: 720x576, 25,000 fps interlaced.
-rendered the project with the MPEG 2 DVD ARCHITECT WIDESCREEN STREAM PAL (plus ac3 for sound)
-opened DVD architect project, with template MPEG 2 DVD PAL WIDESCREEN (16:9) 720x576:50i
when I went to burn it, as I expected it did not tell me to reencode anything.
Thing is, when I watched it I still get constant flickering throughout the whole video.
Any ideas on to why this happens? ive burned projects before and followed the steps AFAIK correctly and flickering has been minimal.
Thank you very much.
eric pautsch
Re: TV flicker on DVD after aparently doing everything right
on Jun 16, 2012 at 10:32:02 pm
Whats the field order of your source and is it matched in the encode?
Ryan Garcia
on Jun 17, 2012 at 1:18:08 am
How do I see the field order of the source?
I checked and apparently the video was rendered with the lower field first. Should it be upper field first or progressive scan?
Thank you.
eric pautsch
on Jun 17, 2012 at 5:13:55 am
Try upper and see if that works
Bill Stephan
on Jun 18, 2012 at 5:30:57 pm
PAL is always upper field first.
Bill Stephan
Senior Editor/DVD Author
USA Studios
New York City
