ntsc/pal/dvd
COW Forums : DVD Authoring
Russ Carlin
ntsc/pal/dvd
on Jun 5, 2012 at 1:37:27 pm
I have footage that is 29.97fps and i need to put this onto a DVD for client. I'm in the UK so i understand that 29.97 is an NTSC format?
I've burned a disc and it won't play, i'm guessing it's because it's NTSC footage? Is this correct? How can i get it onto a DVD that my client can play?
Any help much appreciated!
Russ
Carrrrrrr Carrrrrrrrrrrrr
Michael Sacci
Re: ntsc/pal/dvd
on Jun 5, 2012 at 3:39:14 pm
There are a lot of reasons a disc will not play. If your footage is 29.97 then yes it is NTSC. All computers can play either NTSC or PAL and most PAL DVDs can play NTSC disc. You cannot bring PAL footage into a NTSC project in dvdsp or vice versa.
Why it doesn't play. You have to give a lot more info.
Russ Carlin
Re: ntsc/pal/dvd
on Jun 6, 2012 at 1:04:07 pm
Ok thanks very much, i'll have an hour spare later so will put more details of what's happening down. Thanks!
