DVD authroing from Mpeg4
COW Forums : DVD Authoring
Diane Mason
on Feb 15, 2012 at 5:45:44 pm
Hi, I downloaded an Mpeg4 from Vimeo and would like to burn a DVD, high def if possible. What steps should I take? I have IDVD and DVDStudio Pro. Also FCP, if needed.
Thank you!
Diane M
Filip Kubiš
Re: DVD authroing from Mpeg4
on Feb 15, 2012 at 6:30:54 pm
Hey, what I would do and what worked for me most of the times:
1. Use Quicktime 7 (I would use Squared 5 - MPEG Streamclip) to convert the Mpeg4 to Uncompress 10bit
2. Put that giant into Compressor and use that to convert it to propper Mpeg2 (m2v and ac3) for authoring
3. DVD SP
This is what I do. Maby someone will tell you you can skip the step 1. but this works for me every time :-)
And watch out! Sometime I got few white frames at the beginning and at the end of the film. Just get rid of them with QT :-)
GL
_____________________________________________________________________________________________________
DVD bitrate calculator: HERE
DVD Bit Budgeting tool: HERE
Dual-Layer Break tutorial: HERE
Anti-aliasing PS plugin: HERE
Other very useful stuff: HERE
DVDSP Manual: HERE
Michael Slowe
on Feb 19, 2012 at 11:24:51 am
You can't have an HD DVD. DVD's are SD but can be made from HD but that has to be downscaled first. If you want to play HD material then Blu-Ray (BD) is the way to go. But you need an BD burner to do that and the right software - I use Toast Titanium Pro 11 for that, but there are others.
Michael Slowe
