DVD Architech
COW Forums : DVD Authoring
Steve Cheramy
DVD Architech
on Jan 27, 2012 at 1:34:07 am
Is there a way in DVD Architech or any other authoring software to embed a pause command? I have to make a training DVD that will need to be paused at certain times, and I need a way to have the pause automatically happen.Thanks
eric pautsch
Re: DVD Architech
on Jan 27, 2012 at 4:20:26 am
DVD Studio Pro has this function
Steve Cheramy
Re: DVD Architech
on Jan 27, 2012 at 6:26:34 pm
I am on a PC and DVD Studio Pro seems to be a mac only software.
Michael Sacci
Re: DVD Architech
on Jan 27, 2012 at 6:33:47 pm
The way I do this pause in to place the command on the chapter markers. I don't use DVDA so I can only give general advice.
The key is that you place the command on the chapter BEFORE the one you want the pause to be on. So it the pause happens at chapter marker 3, the command is entered in chapter marker 2. When the device plays through 2 it will then pause at the next marker.
Note that this action goes away if you are fast forwarding over either marker.
Steve Cheramy
Re: DVD Architech
on Jan 28, 2012 at 3:03:30 am
Do know how to isert a pause command into a marker in DVD Architect?
Steve Cheramy
Re: DVD Architech
on Jan 28, 2012 at 3:35:16 am
Or do you know how to insert a pause command in Encore?
eric pautsch
Re: DVD Architech
on Jan 28, 2012 at 6:20:46 am
You'll need to get the demo yourself and try it out. DVDSP is the only tool I know, other than Scenarist, that will do this.
