Interlacing
COW Forums : DVD Authoring
Sean Simms
Interlacing
on Jan 6, 2012 at 9:20:32 pm
I am using DVD studio pro 4. I imported a fcp mov reference file and it made an mpeg file....when I play it in the DVD Studio Pro viewer area it looks fine but when I put it into the simulator it plays with interlaced lines. How can I change this?
Sincerely,
Eros Salvatore
http://www.erossalvatore.com
Michael Sacci
Re: Interlacing
on Jan 6, 2012 at 9:32:11 pm
Quality cannot be judged in Simulator, test a build in DVD Player software or better burn a disc.
You need to give more info. What did you make the mpeg movie? Is it a m2v? What is your source files?
Sean Simms
Re: Interlacing
on Jan 6, 2012 at 9:37:25 pm
yes its an m2v...dvd studio pro made it automatically after I imorted the fcp reference file (not self-contained)
Sincerely,
Eros Salvatore
Michael Sacci
Re: Interlacing
on Jan 6, 2012 at 9:43:25 pm
If you want real answers give real information and settings. If you cannot there is no way to help you.
Did you test the way I said?
Sean Simms
Re: Interlacing
on Jan 6, 2012 at 9:48:53 pm
What settings do you want?
The source is mini-dv SD 720x480, DVCPRO NTSC, 29.97 fps, Lover (Even) Filed Dominance (I tried changing Field Dominance to None but it didn't help.
Just finished the burn, everything is okay.......
Sean Simms
Re: Interlacing
on Jan 6, 2012 at 9:42:47 pm
I'm doing a test burn right now1
Sincerely,
Eros Salvatore
Sean Simms
Re: Interlacing
on Jan 6, 2012 at 9:49:18 pm
Thanks for the fast response though!
Chris Tompkins
Re: Interlacing
on Jan 18, 2012 at 1:05:55 pm
Reference or self-contained makes no diff.
Computer screens are not meant to display interlaced material correctly.
Don't judge your video on the computer screen.
Chris Tompkins
Video Atlanta LLC
