5.1 and stereo mix possible in one audio file?
COW Forums : DVD Authoring
Guy Fixsen
on Sep 17, 2011 at 8:24:16 pm
I am trying to author a DVD for a short film for which I have both a stereo mix and a separately mixed 5.1 surround mix. As the film is being sent to festivals, it's best that it has no menus and simply plays the film when put into a player. I realise that I could just put the 5.1 mix on and have it downmixed for those viewers who don't have surround but that will be the overwhelming majority and so it seems silly to have the downmix performed when it will be inferior (compressed) to the stereo mix I already have.
Is there a way to have an 8 channel audio file - two channels the stereo mix and the remaining 6 being 5.1? And if so will DVD players pick the right channels as appropriate?
Or is the only way to do this to have a menu and two separate audio tracks?
Thanks for any thoughts!
Guy
Michael Sacci
Re: 5.1 and stereo mix possible in one audio file?
on Sep 17, 2011 at 11:21:49 pm
No each has to be in it's own stream. I doubt many festivals are watching DVDs in a 5.1 setup.
You put but streams in, then simply have a menu that asked which audio and that sets the stream and starts the movie.
Guy Fixsen
on Sep 17, 2011 at 11:55:15 pm
Thanks for that!
I guess I'll just give the festivals a stereo mix on the DVD and send a 5.1 if one of the big ones wants a proper copy...
Michael Sacci
on Sep 18, 2011 at 12:37:38 am
Not sure if you are planning to send the Stereo file as uncompressed. If you are DON'T, make sure it is encoded as ac3.
Guy Fixsen
on Sep 18, 2011 at 1:31:32 pm
I was definitely planning to use the compressed aif/ wav! Why would you suggest reducing the quality to an ac3? Are there players out there that don't play aif?
Michael Sacci
on Sep 19, 2011 at 4:52:12 am
There is no such thing as compressed Aif or wav on a dvd, it will be uncompressed and it takes up 1.5 Mbps of bitrate. Other than high end music titles nobody uses anything but ac3.
All players have to be able to play PCM audio but because of the bitrate it can cause problems, especially on DVD-Rs.
In the end we all make our own decisions.
Guy Fixsen
on Sep 19, 2011 at 9:30:13 am
Hi Michael
Thanks for your perspective. I mistyped - I meant 'uncompressed' of course :)
Can you suggest what is a sensible maximum total bitrate for a DVDR?
Guy
Michael Sacci
on Sep 19, 2011 at 6:41:59 pm
IF using a VBR encoding method, I will not go over 7 Mbps for the max.
If using CBR I will not go over 7.5 Mbps.
Stereo is always compressed to ac3 @ .192 Mbps
NOTE: 2 titbits to always do when making the ac3. 1) Make sure the Dialog Normalization is set to -31 dB (this turns it off, which is what you what). 2) On the third tab set Compression to NONE. (it still gets compressed, this is more of a compression scheme). Doing both of those will eliminated surprises to the audio.
Guy Fixsen
on Sep 19, 2011 at 8:21:02 pm
Thanks for that Michael! I've done as you said.
Elliott Balsley
on Dec 9, 2011 at 12:07:24 am
You can encode both mixes on the DVD and set the stereo track as the default. Even without a menu, the projectionist could select the 5.1 track using the DVD player remote if he or she wanted to.
