MPEG2 encoding
COW Forums : DVD Authoring
John Culleton
MPEG2 encoding
on Sep 6, 2011 at 5:02:07 pm
can someone give some tips on encoding to MPEG2 plz? main problem i'm having is with motion blur on fast tracking shots, using TMpeg5 btw
eric pautsch
Re: MPEG2 encoding
on Sep 6, 2011 at 8:21:15 pm
Are you matching your source's field order?
John Culleton
Re: MPEG2 encoding
on Sep 6, 2011 at 10:18:13 pm
source is HIDEF pal mov so progressive and i want to encode to SD NTSC MPEG2,
i'm using interlace and top field for the mpeg and encoding at around 7k
Noah Kadner
Re: MPEG2 encoding
on Sep 6, 2011 at 10:30:18 pm
Should be field set to NONE if it's progressive footage.
Noah
40% discount for Creative Cow users with code ccow2011 at Call Box Training.
Featuring the Panasonic GH2 and GoPro HD Hero.
John Culleton
Re: MPEG2 encoding
on Sep 7, 2011 at 6:33:21 am
original fottage is progressive so no field, but the MPEG should be interlace, top field, right?
Noah Kadner
Re: MPEG2 encoding
on Sep 7, 2011 at 6:27:39 pm
I don't know your encoder specifically but MPEG2 encodes can indeed be progressive- as are generally any Hollywood DVD originated on film or 24p digital.
Noah
John Culleton
Re: MPEG2 encoding
on Sep 7, 2011 at 6:59:36 pm
thanks Noah, that's SO much better, i always thought MPEG2 had to be interlaced, oh well...
john
Noah Kadner
Re: MPEG2 encoding
on Sep 8, 2011 at 4:13:16 am
Glad to be of help :)
Noah
