DVD Studio Pro 4, return to menu comand
COW Forums : DVD Authoring
Casey Early-Krueger
on Jun 7, 2011 at 2:31:24 pm
I'm building a DVD in DVD studio Pro 4. A logical function for the DVD to have is for the user to be able to jump back to the menu when every they like during playback of any track. On each of my tracks, under User operations, I have everything enabled (unchecked). As far as I have been able to tell, this function should work. But wether I simulate or burn a disk I can't jump to the menu unless I hit the end jump button which takes me to the end of the track which is cued back to the menu.
I greatly appreciate any assistance you can offer. I hope this is enough information, I'm not sure what else to say.
Thank you
Casey Early-Krueger
Re: DVD Studio Pro 4, return to menu comand
on Jun 7, 2011 at 3:47:10 pm
I tinkered around a bit more. Sometimes all you need is some fresh air and a fresh perspective. So for anyone else who might have looked at this:
select the track, go to the inspector, under the General tab, there is a section for remote control. Select the Menu options, go to the menu you want the track to jump to. Repeat for each track.
