Premiere CS5: HD 1280x720 30p to SD NTSC DVD
COW Forums : DVD Authoring
Dmitriy Dribinskiy
on May 26, 2011 at 5:13:55 pm
I just finished editing my first CS5 project. Now I need to create a SD NTSC DVD. The original footage (timeline) is 1280x720 30p. What settings/preset/format should I use (i.e preset for MPEG-2 DVD)? Thanks!
Jon Geddes
Re: Premiere CS5: HD 1280x720 30p to SD NTSC DVD
on Jun 2, 2011 at 2:31:59 pm
Please read this article by Adobe's Todd Kopriva on GPU accelerated scaling in Premiere CS5 (and above).
http://provideocoalition.com/index.php/adobe/story/scaling_in_adobe_premier...
He explains how you will achieve higher quality scaling by using the Mercury Playback Engine, which uses the Lanczos 2 algorithm.
If you do not have a Mercury Playback Engine supported GPU, your downscaling of HD to SD will only use the bicubic algorithm, which is greatly inferior.
Jon Geddes
http://www.precomposed.com
