Problems playing burnt DVDs from Studio Pro
COW Forums : DVD Authoring
Sarah Bright
on May 26, 2011 at 9:57:35 am
Hi guys...
Having some problems playing a certain film that has been made through DVD Studio Pro...
It's an hour programme that we have exported from FCP and run through compressor using the 'DVD: Best Quality 90 minutes' setting.
Then running through DVD Studio Pro.
The original file is DVCProHD 1080i50 BUT we've also used a DV Pal version too.
Basically the DVDs skip, or judder and stop playing. Usually about half way through, but sometimes just at the beginning.
We've redigitized the tape and made a new QT and repeated the process.
We use Verbatim DVDs and don't have any problems with other projects.
We just bought some JVC DVDs.
Ay suggestions welcome!
eric pautsch
Re: Problems playing burnt DVDs from Studio Pro
on May 26, 2011 at 12:45:00 pm
What were your bitrate settings and did you use ac3 audio?
Sarah Bright
on May 26, 2011 at 2:18:51 pm
Currently 192kbps, The DVD uses Dolby Digital Professional 2.0 and MPEG-2 6.2Mbps 2-pass.
Sarah Bright
on May 26, 2011 at 2:16:48 pm
Yeah, sorry... it is AC3.
eric pautsch
on May 26, 2011 at 2:29:59 pm
Right but it helps to know the exact settings. Look in the inspector for Compressor. Keep the peak setting under 8 if you can
Sarah Bright
on May 26, 2011 at 2:45:56 pm
Peak setting for which? And where do I change it?
In the Mpeg-2 settings, the Average Bit Rate is set to 6.2Mbps
And the Maximum Bit Rate is 7.7.
eric pautsch
on May 26, 2011 at 3:26:03 pm
Yes....the max setting is fine. Throw away the jvc discs and try another batch. Have you tested on more than one player?
