Blu Ray to SD DVD
COW Forums : DVD Authoring
Dmitriy Dribinskiy
Blu Ray to SD DVD
on May 3, 2011 at 11:55:48 am
Hello,
Can any one suggest a way to convert blu ray DVD to standard def DVD? I am a wedding videographer and most of my projects are HD. And now in order to provide client with SD DVD I have to spend a lot of time for transcoding, re-editing, etc. Thanks!
David Resnick
Re: Blu Ray to SD DVD
on May 16, 2011 at 10:41:04 am
Did you ever get a good answer? I'm looking to do something similar.
Patrick Morgan
on May 25, 2011 at 2:23:23 pm
what dvd authoring program are you using?
Dmitriy Dribinskiy
on May 25, 2011 at 3:02:42 pm
encore cs5
Patrick Morgan
on May 25, 2011 at 3:08:07 pm
All you should have to do is open the encore project go to your build tab then change the format from Blu-ray to DVD and then the output to DVD Disc. This is what I do.
