Is this hi-def?
COW Forums : DVD Authoring
Andrew Harman
Is this hi-def?
on Mar 17, 2011 at 11:25:28 pm
Is this hi-res?
The reason i ask is when i burn a disc, it comes up as 420i.
What the!!
Thanks All
Michael Sacci
Re: Is this hi-def?
on Mar 18, 2011 at 12:05:00 am
that is but a DVD is SD (and it is 720x480, there is no 420).
Andrew Harman
Re: Is this hi-def?
on Mar 18, 2011 at 12:07:54 am
but with Toast Pro, you can burn hi-def onto a standard DVD (you dont get much data on there).
So thus if my original was hi-def, then Toast is doing something to it?
Thanks All
Daniel Ludwig
Re: Is this hi-def?
on Mar 18, 2011 at 1:06:30 pm
with toast you can burn HiDef on DVD, correct. it will create a AVCHD-disc that could be played in several BD-players but it´ll be no Blu-ray disk then.
AVCHD-discs coulnd´t have a menu, so if you would like to have a menu on your disc you need to think about burning a real BD.
cheers
danny
