Authoring dvd for full screen 16:9 viewing on 42" flatscreen
COW Forums : DVD Authoring
Charles Leisenring
on Mar 16, 2011 at 6:21:35 pm
I need some help working out a technical problem:
I am shooting on the Canon XHA1s, capturing 1440x1080i footage onto an SD MiniDV cassette.
I import into FCP and create a sequence with the same parameters.
I have exported this sequence to DSP using Compressor settings for 90 Min Best Quality SD.
In DSP I have set up my project to be SD 16:9.
The DVD burns and plays fine, however there are letterbox bars.
What I am wondering is whether or not my workflow needs to be modified or my expectation.
All I want to do is to have this footage play full-size on a 42" flatscreen. As of now, it is letterboxed.
Can anyone help me to identify a simple, standard workflow for creating a DVD that will play full screen on a flatscreen HD tv? And if so, how will this same video work for a standard 4:3 tv?
Unfortunately, Blu-Ray is not an option, but I want to work all of this out as best I can before taking on client contracts.
Noah Kadner
Re: Authoring dvd for full screen 16:9 viewing on 42" flatscreen
on Mar 17, 2011 at 4:43:45 am
Are you sure the DVD player is set to output anamorphic footage? And that your DVD assets are 16:9 anamorphic, DVDSP tracks set to "16:9/letterbox"
-Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Charles Leisenring
on Mar 17, 2011 at 2:05:17 pm
Hi Noah, Thanks for taking the time to reply.
On my first burn I did set up DSP for 16:9 BEFORE beginning my project or importing ANY assets. I did a test run with one of my sequences after doing a little studying and made sure it was anamorphic before I sent it to compressor. It yielded the same results, so I will see what I can to trouble shoot the play settings of the DVD players available.
While I have you here, was wondering if you might be able to help me with one more thing- When I build/burn and create the TS files, is there any way to re-use these in DSP for multiple discs at a time, or will I need to purchase a program such as Toast?
Thanks again for your time and guidance! As much work and time as it takes, I truly do love sussing out all of the technical aspects required to create a smooth workflow that will produce consistently great results!!!
Daniel Ludwig
on Mar 17, 2011 at 6:53:14 pm
charles,
you can create a disc-image using DVDSP and burn it using apple disk utility, so you donĀ“t need to get toast.
the disadvantage is, you can only burn 1 disk each time. if you would like to burn multiple DVDs at the same time, you need to install 2 instances (copys) of toast on your computer, so each of them could be started and burn a disk to individual burners.
cheers
danny
