Resolution and codec question
COW Forums : DVD Authoring
Bryce Conlan
on Mar 12, 2011 at 12:03:41 am
I'm starting in on a documentary and I would like to make it available on DVD. What resolution and codec should I be working in to maintain the highest quality in the final product?
Daniel Ludwig
Re: Resolution and codec question
on Mar 12, 2011 at 6:43:46 am
bryce,to answer this, you might give us a bit more informations what should happen with your documentary.
- which cam do you use for your shoots
- will it go to cinema
- will there be a BD
- what is your budget
- on what kind of system will it be edited
- will it be a PAL or NTSC-DVD
in general you could say: higher quality input will bring better quality in your output.
so you might go uncompressed 8bit or maybe apple pro res HQ or 444 depending on your workflow.
maybe you´ll have a offline/online HD-2K or 4K-edit with a big color-correction, so you might give us a bit more informations.
cheers
danny
