Burn movie to Blu-ray?
COW Forums : DVD Authoring
Andrew Harman
on Feb 24, 2011 at 10:27:04 pm
First time post and not sure if its in the right area.
I have a file generated from Fotomagico Pro. as you can see, when i open the file in quicktime on the mac, its looks great and seems the right specs.
Essentially the end aim is to have this look as good on a hi-def LCD screen (we have a 52 inch).
I know the screen at hi-def is 1920x1080.
Its just when i burn the blu-ray through Toast, its not looking as crisp.
I may be doing it wrong or the disc is as good as it will be.
Help!!
Thanks All
Daniel Ludwig
Re: Burn movie to Blu-ray?
on Feb 25, 2011 at 7:37:55 am
hi andrew,
the first question would be: did you create your sliedshow in 1080? if not - your programm will be upscaled that wont result in good, crispy quality.
another point: toast encoding is no high-quality encoding - so if you would like to have a nice picture I would advice to use adobe encore for BD-authoring and do the encoding using adobe media encoder, apple compressor or even better.
another issue is your BD-player or display. I don´t know what you´ve done: 1080interlaced or 1080progressive.
depending on your player-setting it wont be displayed correct on screen - maybe it would be deinterlaced where it is progressive or wise versa.
this all gives you a bad picture.
you see, there are several gaps to be awared.
cheers
danny
Michael Slowe
on Feb 25, 2011 at 4:48:23 pm
Daniel, I'm surprised what you say about Toast's BD encoding. I'm dragging to Toast 10 a ProRes HQ 422 QT .mov file (1920 X 1080i) and getting great BD's. They look fantastic and even examined close up on a big screen there is no noise and a great picture. Are saying that a BD encoded in Encore would be even better?
Michael Slowe
Daniel Ludwig
on Feb 25, 2011 at 4:53:33 pm
hi michael,
both programms using the same source-code: mainconcept encoder engine, but you have less possibilities to set within toast.
I´ve seen a lot toast-encodings and they mostly have been bad.
I would prefer to use adobe media encoder or compressor instead and do the authoring within encore.
cheers
danny
