Pdf files combined with video files in Toast 10 and DVD Pro
COW Forums : DVD Authoring
Mair Musafija
on Feb 21, 2011 at 4:33:05 pm
I have followed treads in this forum and decide to go Toast Titanium 10 Route when authoring combination of video and PDF files. So instead of using @ccess in DVD Pro I used DVD ROM (UDF) route in Toast 10.
But the question arises - how to have button directing to PDF files that are added to Video TS file in MY DISK.
In other words is it possible to have Menue created in Toast 10 - DVD Rom (UDF) stream?
Mair Musafija
Video Producer
Toronto, Canada
Michael Sacci
Re: Pdf files combined with video files in Toast 10 and DVD Pro
on Feb 21, 2011 at 4:49:52 pm
That is what does not work, with any software (most of which have be left to die).
If you want you simple put a menu that tells people that there are files on the disc in a folder names "x"
BTW, you add the DVD-ROM material in DVDSP without going to DVD@ccess. It is the linking that causes the problems.
