PAL to NTSC
COW Forums : DVD Authoring
Krish Shrikumar
PAL to NTSC
on Dec 9, 2010 at 1:14:31 am
Hey,
I was looking for some advice,
I'm based in the UK and have a project that is currently in PAL, but I need to send it over to the states and I need to convert to NTSC. From reading articles online, there doesn't seem to be definitive guide on conversion. I've gone through compressor and exported an NTSC version but I wanted some advice to ensure that it works (I dont have an NTSC dvd player to test it on)
Thanks in advance,
Krish.
p.s im on Adobe Encore & DVD Studio Pro.
Daniel Ludwig
Re: PAL to NTSC
on Dec 9, 2010 at 9:18:11 am
Hi Krish,
you can playback NTSC-DVDs on PAL-player but it wont work the other way round.
if you need to convert PAL to NTSC I would advice to use compressor with framecontrol. you should go 29.98 NDF and encode it as 29.98 NDF (progressive) otherwise you could get in trouble with the field-dominanz.
note: it´ll take a bit of time to create your NTSC-film out of your PAL-material.
cheers
danny
Krish Shrikumar
Re: PAL to NTSC
on Dec 9, 2010 at 10:45:19 am
Thanks Daniel.
I've done that and it seemed to have exported okay. Are there anything I need to lookout for when burning the DVD on Encore?
Cheers,
Krish
Daniel Ludwig
Re: PAL to NTSC
on Dec 9, 2010 at 5:32:57 pm
hi again,
I wold prefer DVD SP but Encore will be OK as well.
cheers
danny
Michael Sacci
Re: PAL to NTSC
on Dec 9, 2010 at 5:39:43 pm
Is your footage 25i or 25p? If you shot and edited your footage at 25p you should retime the video to 24p NTSC, there is zero quality loss that way.
