Menu is 4:3 but project is 16:9 in DVD Studio Pro
COW Forums : DVD Authoring
Richard Doyle
on Nov 14, 2010 at 4:19:11 pm
I just burned an SD DVD in DVD Studio Pro (footage is all 1080 25p). The menu is a DVD Studio Pro template (tweaked). When I put the disc into the player, the menu comes up as 4:3 (square) and then when I click 'play', the DVD plays in 16:9 as it should. Do I have a setting wrong or something? Thanks.
Filip Kubis
Re: Menu is 4:3 but project is 16:9 in DVD Studio Pro
on Nov 18, 2010 at 5:22:43 am
Well you obviously did not set the menu 16:9 :-)
You do that by clicking on: Outline tab -> MENU (the one that is running 4:3) -> in Inspector under Menu tab you see Display Mode -> there you can choose whether you want your menu 16:9 or 4:3 ...
That should do. But of course not every menu is composed for 16:9 so you can end up with deformed menu. Lets see how smart the template is...
