2 hour Avid timeline to 1 hi-res DVD
COW Forums : DVD Authoring
Sharon Kaufman
on Oct 14, 2010 at 4:09:04 pm
I've edited a 2 hour concert video on Avid 5.0 (PC) and need to put it on one DVD @ hi-res. I can barely fit one hour on a DVD! What's my best option.
Michael Sacci
Re: 2 hour Avid timeline to 1 hi-res DVD
on Oct 14, 2010 at 4:23:29 pm
You can do to a Dual-layer DVD but capacity is a brick wall, no getting around it.
If you are using PCM (uncompressed stereo) and a 5.1 mix that can really eat into your video bitrate. What audio streams are you using? If you are not using PCM audio you should be able to get a good encode even for a DVD-5. (4.6 Mbps for video).
Stephen de Vere
on Oct 14, 2010 at 7:42:36 pm
If you want good quality video at that sort of average bitrate then an Avid is unlikely to be the encoder to do it. Something like CinemaCraft doing 6+ passes in the right hands should easily give a top result for two hours on a DVD-5.
