DVD Studio Pro: "incompatible format"
COW Forums : DVD Authoring
Stephanie Holz
on Sep 23, 2010 at 11:14:49 pm
ok, so some progress has been made,
I exported using "current settings" for a .mov file, then brought into compressor, and made a custome setting (H264)--- did I see DVD SP doesn't support this? The image quality of the resulting file looks good, but it says its a quicktime movie, and DVD SP still says "imcompatible format"--- from what I can tell, DVD SP seems to like m2v files, but every time I make one, the image quality drops radically. Is there away to make a m2v file with more sharpness?
many many thanks!!!!
Noah Kadner
Re: DVD Studio Pro: "incompatible format"
on Sep 24, 2010 at 12:25:46 am
Nope- DVDs are only MPEG-2. This is in your manual.
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Michael Sacci
on Sep 24, 2010 at 12:42:22 am
[Stephanie Holz] "and made a custome setting (H264)"
H264 should NEVER be in the DVD workflow, NEVER!.
I'm not a bitvice fan, while it does a good job, it seems like I run into pixelation problems a lot more then with compressor.
I would keep this simple.
From FCP, send the sequence to Compressor (Send to Compressor command)
Start with any DVD Prest
In the Encoder Button
In Video Format
Frame Rate: <29.97>
Aspect <16:9>
Field Dominance: Upper
In Quality Tab - change the encoding method to CBR and
Bit rate to 7.5
In the Frame Control Button
Frame Control
Resize Filter:
Encode the audio to ac3.
© 2018 All Rights Reserved
