Manual Scene Selection vs Automatic
COW Forums : DVD Authoring
Brad White
on Jul 15, 2010 at 9:35:04 pm
Using Architest Pro 5
I'm stuck. I'm trying to create a sub-menu within "Manual Scene Selection", to play only the chapter/scene I select on the menu, and then return to the sub-menu. I followed the step-by-step on page 57 of the User Guide (added scene/chapter markers and the copy/paste instruction) with almost the results I want; ie. I can get the individual scenes to play with the selected button, but all the scene buttons are on the "Main Menu" along with the button that plays the entire video. If I use the "Automatic Scene Selection" method on page 56, I get the sub-menu but each scene selection starts and plays through to the end of the video (as it should). I need the sub-menu as I have 18 scenes (buttons).
So, how do I get a sub-menu for manually selected scenes that play then return to the sub-menu?
Scott McDermott
Re: Manual Scene Selection vs Automatic
on Jul 28, 2010 at 5:33:07 am
Sounds like you need to make a STORY.
in Graphical view click on the track that has all the chapter markers ( your PLAY ALL)
Click Add Story
story tab now shows all chapter markers drag from Left to Right to create story.
(in your case only one chapter marker.)
repeat 17 more times
END JUMP each STORY one back to where ever you want them to go
hope that helps...
Scott McDermott
on Jul 28, 2010 at 6:13:44 am
Sorry, Its late gave you DVD STUDIO PRO instructions....
but they would work!
