DVD Architect Pro 5
COW Forums : DVD Authoring
Tony Smith
DVD Architect Pro 5
on Jul 6, 2010 at 1:19:47 pm
Hello, I've just started using DVD Architect Pro 5 under Windows 7. So far it works fine except that having burned the first disc successfully, when trying immediately to burn another it appears to do the burning but then ejects the disc with the message that it is an incompatible disc without completing the burn.
Does anyone have any idea what is going wrong?
Thanks for any help.
Tony Smith
Dave Lozinski
Re: DVD Architect Pro 5
on Jul 26, 2010 at 2:14:48 am
Out of curiosity, after you burn the first disc, have you tried saying "no" to burning a second disc? Then returning to the project, going through the prepare/burn process again, and then seeing if it does it successfully?
http://www.davelozinski.com
Tony Smith
on Jul 26, 2010 at 10:09:45 am
Hi Dave,
Thanks for the reply. Yes I did try a while ago as you suggest and it still caused problems. In the end, because I only use the software in a very simple way, I went back to version 4.5 and it worked fine.
I suspect there was an installation glitch with version 5 which I will look into in due course when time permits.
Once again thanks for your reply.
Tony Smith
