Compressor to DVD Studio Pro (compressor fails)
COW Forums : DVD Authoring
terry brown
on Apr 12, 2010 at 7:45:10 pm
Recently (I think right after I upgraded to Leopard) Compressor stoppe working. Is there a solution (in MPEG Streamclip or FCP) so that I may import into DVDSP?
terry wilson
Re: Compressor to DVD Studio Pro (compressor fails)
on Sep 12, 2010 at 2:24:59 pm
dunno what sort of quality requirements you are looking for, but couldn't you export a loss-less animation file from FCP and use DVDSP's encoder? The quality is about as good as compressor was (yes compressor is mostly broken).
If you do this however, encode the audio separately, use compressor to make ac3 files, it still works for that. ac3 are a much lower bit-rate, allowing you to almost double your video bit-rate.
