DVDSP DVD plays in my MAC but not in a DVD Player
COW Forums : DVD Authoring
Phil LeBeau
on Apr 7, 2010 at 4:18:33 pm
Don't know where to start but I created a DVDSP project with a main menu and it has lots of other videos and menus added to it.
Once I burned it to a DVD - it will play on my MAC but will not play in my DVD player. Everything simulates fine. As far as I know the dvd is a DVD-r.
I have the menu as first play...
When you put the dvd in a player - it loads then stops.
It is a SD project but my video is 960x540 - I didnt shoot it - the video was given to me and I had to make a dvd out of it.
I also had to convert the video to a .mov file using Stream Clip. But even if the video was a problem, why doesn't my menu come up first?
Thanks for any help - this is a work project and it will be duplicated.
Phil LeBeau
Re: DVDSP DVD plays in my MAC but not in a DVD Player
on Apr 7, 2010 at 4:25:37 pm
How can I tell if my project is SD or HD and how do I make sure that my new project is in SD and not in HD?
Phil LeBeau
on Apr 7, 2010 at 5:19:00 pm
I figured it out - Crazy HD DVD button was pressed - Arg - back to the drawing board.
Michael Sacci
on Apr 7, 2010 at 4:25:43 pm
Most likely you have created an HD DVD disc, even if your assets are SD, it will not work.
If is is a HD DVD you will have to reauthor the disc as a SD DVD.
