DVDSP: combine multi language with mixed angle?
COW Forums : DVD Authoring
Michael Lohrengel
on Mar 15, 2010 at 12:55:03 pm
Hi Forum,
I have to do a multi language dance instruction DVD that not only contains different audiostreams for each language but is supposed to occasionally show different video content according to the choosen language. I wonder if I can controll the mixed angle feature using scripts in such a way that the video content ist following the language.
Has anyone done somthing like that with DVD Studio Pro and give me an idea of how to prgram scripts for that purpose?
greetings from Berlin, Germany, Michael Lohrengel
Michael Sacci
Re: DVDSP: combine multi language with mixed angle?
on Mar 15, 2010 at 7:55:24 pm
It has been forever since I have used mixed angles but here are a couple of general thoughts.
1st, if you always want to tie the audio choice with the angle you have to turn off the audio/angle buttons of the remote. You don't want the viewer to be able to switch audio streams in the middle of watching the video.
Then you set your language menu as that a button (say for english) will set audio stream and video stream to one, the spanish button then sets the audio to stream 2, and sets video angle to 2.
Most likely there is no scripting needed.
