best red 2k down to Blu_ray
COW Forums : DVD Authoring
ross byron boughton
on Jan 21, 2010 at 4:43:22 pm
hi guys have been using share to compressor to burn blu-Ray disks
i have toast 10 and am thinking about downsizing the footage to 1080i first
(which codec and frame rate is best can i stay in 23.97?)
then going to toast
as sometimes burning though compressor is unstable and you can not do a reburn after a few days if the client wants more
any thoughts would be great
tia
Ross byron
Ross Byron Boughton
Editor / Webmaster / Sound Designer 917-538-0823_
E-mail:rbellevue@aol.com http://www.inch.com/~bellevue/
Ross Byron Boughton
ross byron boughton
Re: best red 2k down to Blu_ray ps
on Jan 21, 2010 at 8:18:37 pm
PS i have the adobe media encoder 4 which really seems to fly
Ross Byron Boughton
eric pautsch
on Jan 22, 2010 at 5:20:45 am
You need to encode a 1920x1080 10bit Uncompressed file @ 23.98. Personally, I'd pay someone with a professional encoder and a little BD know how to do this work. Why shoot with a RED, then use prosumer tools to output a product the client will ultimately see? I can never understand this. Would you hire someone who has no RED experience to shoot?
ross byron boughton
on Jan 23, 2010 at 2:01:49 pm
thanks thats what i thought it might be
what other compression programs or hardware would you be referring to
best
Ross B
Ross Byron Boughton
ross byron boughton
PS best red 2k down to Blu_ray ps
on Jan 23, 2010 at 8:12:16 pm
have had great results with making my SD versions that way as well
i resize and center crop it down to a 720 486 10bit uncompressed then make an mpeg2 out of it
in compressor i use the inspector tab to amp up my setting to best motion and resize 2pass ect.
will do a test and post latter
Ross Byron Boughton
ross byron boughton
Re: PS best red 2k down to Blu_ray ps
on Jan 28, 2010 at 10:13:29 pm
burned on in toast no sound from 1080 24pm 10bit uncompressed
will revist my work flow maybe try a 720 pm
am using duel layer disks gotta say with out the sound the picture was great! on my 40inch tv
Ross Byron Boughton
eric pautsch
on Jan 29, 2010 at 7:10:15 pm
You should see your footage on a good encoder and see what you'd say! :)
