DL Disc Inspection...
COW Forums : DVD Authoring
Dan Nethery
on Dec 2, 2009 at 3:37:41 pm
Does anyone know of a software that can Inspect the integrity of a burn, and or look at the size of the data on one layer of a disc verse the other?
I prefer Mac.
thanx for the input.
Michael Sacci
Re: DL Disc Inspection...
on Dec 2, 2009 at 5:26:28 pm
There is a program called DVDAfterEdit that gives you a lot of ways to look at the build of a disc, It also gives you the ablility to make changes to the disc. Overall a great tool. The problem with any program like that is you have to do a lot of learning to use it right. So if you want something that has an inspect button on it that is not for you. If you want to trace down what is doing on it is extremely powerful. But it is not cheap either.
dvdafteredit.com
