DVDLabPro - How to make a DVD w/ both 4:3 and 16:9 aspect ratio videos
COW Forums : DVD Authoring
Alex Keppler
on Aug 28, 2009 at 1:32:06 am
First off I'm working with DVDLabPro 2.0 and Sony Vegas 7
I wanted to know if there is a way to make a DVD w/ both 16:9 and 4:3 aspect ratio videos, without having to letterbox either of them. Granted, they'll be letterboxed on the TV, but if you'd watch em on a computer, they'd both show up in correct ratio so letterbox
I've tried just putting them both on and rendering but it changes the aspect ratio of all the movies to that of the 1st movies.
thanks
-Alex
William Busby
Re: DVDLabPro - How to make a DVD w/ both 4:3 and 16:9 aspect ratio videos
on Aug 28, 2009 at 6:23:07 am
It's in the encoding you do this, NOT DVDLabPro (or any authoring program, as far as I know). Whatever encoder you're using you have to set the 16x9 flag. I typically export an anamorphic QT Ref file from Avid then import that into the encoder flag it as 16x9 material.
