Embedding subtitles to MPEG2 / M2V ?
COW Forums : DVD Authoring
Stephen Vilas
on May 25, 2009 at 9:19:17 pm
I have just made a MPEG2 multiplexed 720p stream for digital screening on a festival. The master sequence is actually a 2K tiff sequence.
The festival needs subtitles embedded in this film.
I am using Belle Nuit and the subtitles have been made already according to the time code. What software can I use to add subtitles to this MPEG2 stream without having to re-encode everything again. What subtitle format do you recommend? is this even possible at all?
or should i add the subtitles to the m2v file and then mux everything once again? what subtitle format should i use for this and which software allows me to do this?
so my final destination is not a DVD, but a multiplexed file as mentioned above to be played and projected from a media server in a cinema.
Andrew Saliga
Re: Embedding subtitles to MPEG2 / M2V ?
on Jun 3, 2009 at 9:59:20 pm
I am asking the same questions...
Also, I have a question about Belle Nuit. If you create subtitles with it, does it allow you to export a QT file or a MPEG-2 with the subtitle info embedded?
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com
