AC-3 Encoding problem
COW Forums : DVD Authoring
bryan single
on May 12, 2009 at 2:32:05 am
I just dropped 6 aiff files (L, R, C, LFE, LS, RS) into compressor, created a 5.1 Dolby setting, and tried submitting the batch for AC3 encoding. I am given a message "cannot submit batch, unable to connect to background process"
Can someone please tell me what I'm doing wrong? I don't see anything about this in the compressor manual.
John Fishback
Re: AC-3 Encoding problem
on May 19, 2009 at 5:50:36 pm
Try searching the COW for "background process." Use the quotes and I bet you'll find your solution. I remember this happened to me many versions ago, but not the resolution.
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
© 2018 All Rights Reserved
