What settings should I
COW Forums : DVD Authoring
Dan Weinberg
on May 6, 2009 at 7:17:25 pm
I have been creating menus using still photos and text in Photoshop and
then importing them into DVD SP. Once I do this however the image
becomes distorted because the DVD SP project uses rectangular pixels,
while Photoshop uses square.
I have tried different settings in Photoshop: (D1/DV NTSC Widescreen, NTSC D1/DV Anamorphic,
Film/Video setting at 720 x 480, 720 x 540.
Nothing seems to be working.
What am I doing wrong, and what can I do to solve this?
Michael Sacci
Re: What settings should I
on May 7, 2009 at 12:05:58 am
Just use the Photoshop preset for DV/NTSC, if you want/use anamorphic you need to set the display aspect in DVDSP menu inspector to 16:9 Letterbox (or 16:9 Pan and Scan) If you want a full screen 4:3 do not select anamorphic.
© 2018 All Rights Reserved
