DL Discs Burnt in Windows Media Player wont play
COW Forums : DVD Authoring
Gary Spence
on Feb 17, 2009 at 11:50:58 pm
When I use Windows Media Player "burn tab" to burn AVIs to a DVD single layer disc it plays fine but if I use the same process to burn to a DL disc (regardless of size of burn) the disc will not play. (if I render the files to a DVD image then burn to DL they play, but then I lose a ton of space or loose quality) I have made lots of dual layer rendered home videos that all play fine and the AVIs burnt to single layer play fine so does not appear to be a dvd player issue.
I have a Asus P5K MB, Intel quad core CPU, 4 GB ram and an LG dual layer burner running Vista HP. All SW and drivers are latest versions.
Using WIndows Media Player burn tab is so easy - just drag & drop and no compatibility issues or conflicts. Has anyone else run into this and if so did you find a fix??
