Compressor to DVDSP
COW Forums : DVD Authoring
James Dow
Compressor to DVDSP
on Feb 9, 2009 at 3:10:20 pm
I edited an FCP sequence at 23.98 FPS, set a custom compressor setting to change bit rate, also set to 23.98 fps, is there anywhere in DVDSP setup that I need to indicate the 23.98 frame rate? When I import the asset, it is sayiny its a 29.97 track.
James
JPD
eric pautsch
Re: Compressor to DVDSP
on Feb 9, 2009 at 5:31:04 pm
This will explain everything:
http://forums.creativecow.net/thread/155/870715#870715
James Dow
on Feb 9, 2009 at 8:20:07 pm
Eric,
Thank you so much.
James
JPD
