Serious Help Needed!!!
COW Forums : DVD Authoring
stephen reber
on Jan 25, 2009 at 10:40:50 pm
Hey all,
I have a major problem that I need help with. I have a project I need to get out in the morning, but I'm having a problem that I can't troubleshoot.
I have an intro animation that is about 2 1/2 minutes long, where at the end (attached to the intro) is the main DVD menu. I have the animation loop point at about 1 1/2 minutes so the menu would loop and not go back to the beginning of the intro every time the animation ends.
The problem is is that when ever I set the loop point, the buttons no longer work in the "preview" or when burnt to a DVD. When I remove the loop point, the buttons work again.
I've rebuilt this project like 5 times and the same thing happens every time. I even tried cleaning the database. Nothing!
Any advise would be great!
thanks in advance...
Stephen =]
Michael Sacci
Re: Serious Help Needed!!!
on Jan 25, 2009 at 11:13:28 pm
If you use a loop point you cannot build any of the menu in DVDSP. You have to use an overlay file. This has always been the case.
