DVDA ..no burn
COW Forums : DVD Authoring
bob tyson
DVDA ..no burn
on Jan 25, 2009 at 10:14:35 pm
Aloha Gang,
Edit project,mostly slideshow,inV8.0b and render to mpeg2 +ac3. No problem . Load into DVDA 5.0a as a single play movie,no menues and prepares ok. Hangs at 66% which is where the burn starts under make video button.This is on a liteon burner with latest firmware. Tried: lower bit rate of 6.5 form default8,slower burn at 4x,tried memorex-R,tdk+R and verbatum+R.Tried in old copy of Uleadvideostudio and worked but recompressed to lower quality video and sound.Finally ,needed adisk for a banquet last nite, found freeware Imageburn and loaded VIDEO_TS & AUDIO_TS and made a dvd but no joy with DVDA.Picked up a Pioneer burner to swap out to see if DVDA will get happy. Any thoughts??...thanks for your time..bobt
