I need a program to compare a master dvd to a copy. any recommendations?
COW Forums : DVD Authoring
joey loman
on Jan 13, 2009 at 7:50:13 pm
I work at a church that produces and copies dvd's of our services. We are having problems with a dvd's from a particular duplicator and i wanted to see if the duplicator was causing the errors or if it was the master recorder.
Can anyone recommend a program (windows preferred) that can do a bitwise comparison on these 2 dvd's?
Noah Kadner
Re: I need a program to compare a master dvd to a copy. any recommendations?
on Jan 13, 2009 at 8:37:27 pm
Haven't seen one. But if you're having trouble with a duplicator- change. They are literally a dime a dozen these days.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
joey loman
on Jan 13, 2009 at 9:26:56 pm
I'm trying to diagnose whether my master dvd recorder is causing problems or if it's one of our four 10-bay dvd recorders. They are set to automatically detect and set the duplication speed. Is there a correlation between the duplication speed and the number of errors on a disk? I have always assumed that the faster the duplication the more possible errors.
Also, I'm wondering how the dvd master encoding speed (sp/ep) affects the duplicates. is there a correlation between the encoding speed and the duplication speed?
my assumptions have been that a slower recording speed (with less compression) on the master will play better on a duplicate, even with possible duplication errors. and that the slower the duplication speed (12x or 8x) will reduce copy errors.
does the logic hold in this case?
Noah Kadner
on Jan 14, 2009 at 2:12:30 am
Yep- in general the faster the record speed the higher the potential for errors. But if you use verification this shouldn't be a major issue;
Noah
Lucas Fazzary
on Jan 14, 2009 at 3:08:27 pm
Beyond Compare http://www.scootersoftware.com/
