How to add commentary stream in a story
COW Forums : DVD Authoring
Brandon Donnelly
on Jan 9, 2009 at 5:14:33 pm
What would I do if when i want some of the options of the stories to play a different audio track (commentary for example), because when you are going through stories you don't have the same ability to have the buttons set to a different audio track or subtitle file (like a normal play button would give you when you set its destination under the advanced streams option). Is there a way to add something to the story to resort to the second audio track verse the automatic first track which is the videos audio...
Thanks very much, Brandon
