Interlaced/None PNG for menu backdrop - DVD SP
COW Forums : DVD Authoring
Elijah Lynn
on Jan 8, 2009 at 10:30:18 pm
I am wondering if I should be using a interlaced or normal png for my main menu background. I used a interlaced png for a test dvd and some of the text was badly aliased.
Just trying to track down the source of the problem.
Noah Kadner
Re: Interlaced/None PNG for menu backdrop - DVD SP
on Jan 9, 2009 at 5:59:26 pm
You should try BMP or PSD for best quality. PNG is compressed.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Elijah Lynn
on Jan 9, 2009 at 6:48:51 pm
Hi Noah,
Thanks for replying. While PNG is compressed it is a lossless codec and doesn't result in visual degradation. It uses "deflate" to do it's "zipping".
I just realized that the interlaced setting in PNG is more of a progressive download feature and has nothing to do with NTSC interlacing.
So even though it is a lossless codec does DVD SP not handle this correctly? Or maybe it cannot handle the interlaced option(progressive download) I checked. Of course now that I know this I will leave it unchecked but I will also try your advice and just use a flattened PSD and see if that helps any!
Thanks again for your input!
