Change from PAL to NTSC in iDVD?
COW Forums : DVD Authoring
Eoin Ryan
on Nov 20, 2008 at 4:13:28 am
Hi
I'm shooting PAL SD. Using latest version of iDVD to burn a DVD. I want to create an NTSC DVD. If I change from PAL to NTSC, iDVD says it will re-encode everything, and I click OK, and then a message pops up on screen before the burn starts, saying that I am putting PAL material on an NTSC disc. So is this the right way to change from PAL to NTSC?
Thanks.
Heather Martin
Re: Change from PAL to NTSC in iDVD?
on Jan 19, 2010 at 12:26:21 am
I have a movie made in PAL (imovie) and IDVD. Is it a matter of just changing the VIDEO MODE in IDVD to NTSC and encoding again or do I have to change the .mov files too? What should I do?
Cheers, Heather
