Best File to encode 5.1 ac3 from in Compressor?
COW Forums : DVD Authoring
Andrew Williamson
on Nov 17, 2008 at 4:10:40 pm
Hey all,
I've captured a 5.1 mix as individual channels off of a DAT sync locked to the DigiBeta Capture @ 25fps. This audio will need to be given to the DVD authorer as an .ac3 asset, so they can drop into their scenarist project.
I was planning on going about this by making a multi channel aif in Nuendo (the DAW I use) and dropping that file into compressor with an ac3 setting. I don't have compressor available to me right now to run any test, so is this the right way of going about things? Also is there a specific order compressor/scenarist like the L R C RL RR channels?
Many Thanks,
Andy
eric pautsch
Re: Best File to encode 5.1 ac3 from in Compressor?
on Nov 17, 2008 at 5:14:40 pm
You'll need 6 separate AIFFs that will be used to drop into Compressor to make the AC3.
Andrew Williamson
on Nov 17, 2008 at 5:17:46 pm
Is there a specific order for these to be dropped in - or does compressor let you assign which is which?
eric pautsch
on Nov 17, 2008 at 5:26:01 pm
Once you tell compressor you want to make a 5.1 a box will appear where you drag and drop each audio file onto L/R/C/LS/RS/SUB.
Andrew Williamson
on Nov 17, 2008 at 5:27:35 pm
Ace Bro. Many thanks!
