Audio File Read error when the sound is good
COW Forums : DVD Authoring
Sorin Mihailovici
on Oct 21, 2008 at 1:31:16 am
Hey guys
I am working on authoring a DVD SP project and after I overpass some difficulties (thanks David!) I run into a different issue right at the end.
When I am building/formatting the project a few minutes after start it gives me an error saying: 'Audio File Read error".
Although I checked the audio of the file where it gets interrupted and is good, the error message keeps popping up every time I try.
What can I do? Thank you in advance!
Sorin
cowcowcowcowcow
Noah Kadner
Re: Audio File Read error when the sound is good
on Oct 21, 2008 at 5:12:18 am
Perhaps a problem with your hard drive- try moving the original file to another drive and reimporting.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
Sorin Mihailovici
on Oct 22, 2008 at 12:30:52 am
Hi Noah, thanks, you helped me fix the problem.
Now there is one little error left: the chapter marker for the break point. I have set up a chapter marker in every clip but still it says that either Layer 0 or Layer 1 exceeds the maximum layer size allowed. Should I keep setting chapter markers for the break point? The more the better? (I know I could only choose one as the break point, but does it help if I set more?)
Thank you!
Sorin
Noah Kadner
on Oct 22, 2008 at 2:59:16 am
Sounds like you are picking the wrong point for the layer change. Try a different spot.
Noah
