compress from timelime vs. quicktime
COW Forums : DVD Authoring
Chris Waz
on Oct 20, 2008 at 1:40:13 am
How does one get a better quality DVD?
Export an MPEG2 from the FCP timeline or export a same settings QT and make MPEG2 of that?
If QT, reference or self contained?
I am using Compressor.
Thank you.
Noah Kadner
Re: compress from timelime vs. quicktime
on Oct 20, 2008 at 12:06:54 pm
Kinda depends on the source- if it's HDV for example- definitely do not recompress with current settings. Also depends if there's a downconversion involved first. If I'm coming from 720p DVCPROHD for example I typically go to 16:9 SD ProRes HQ first out of FCP and then convert to MPEG-2 in Compressor. As far as how to get better looking final DVDs- that depends a lot on the level of quality of the source footage. Also Compressor itself is not the only MPEG-2 encoder. There's also Bitvice, Cinecraft, etc.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
Chris Waz
on Oct 20, 2008 at 1:53:31 pm
My Source is 23.98 DVCPROHD 1280x1080 16:9.
Noah Kadner
on Oct 20, 2008 at 9:10:03 pm
Then pretty much same workflow I've outlined above would do the trick.
Noah
chris Waz
on Oct 20, 2008 at 9:36:54 pm
I will give it a try.
But it seems odd to me to introduce another codec (prores) into it.
Noah Kadner
on Oct 20, 2008 at 10:09:55 pm
It's what I do but you can compare results to Uncompressed as well. The most important thing is the downconvert anyway. To go directly from DVCPROHD in FCP into Compressor with the downconversion ties up FCP forever with not much difference in quality.
Noah
