DVD Studio Pro + Incompatible .movs?
COW Forums : DVD Authoring
John Eberhart
on Jul 16, 2008 at 3:37:34 pm
I'm trying to author a DVD of a product for the company I work for, however, after exporting the freshly edited footage to Quicktime, only half of the files were "compatible" with DVD Studio Pro.
I exported them all the same way, and sequentially. The only difference is (well, at least that I can tell) that the ones that I am able to import into DVDSP are in the dimensions of 720x480, whereas the "incompatible" ones are (for some reason) 1280x720.
If this is a problem with Final Cut (let me know) then I may cross-post this if applicable.
Any insight and/or help would be much appreciated.
John E. Eberhart
eric pautsch
Re: DVD Studio Pro + Incompatible .movs?
on Jul 16, 2008 at 4:35:04 pm
DVD is 720x480 only. Those QT didn't import because they are 1280x720. You should be using Compressor to Encode your QTs - NEVER just drop a QT into DVDSP and let it doing the Encoding.
Take them into Compressor and encode 16x9.
