Encore CS2 - button type - why use them? normal - chapter - next - previous - main
COW Forums : DVD Authoring
Jason Brown
on Jun 26, 2008 at 1:16:12 am
I'm trying to figure out if there is any benefit to using the *button type* pulldown in Encore CS2.
Does it build/author the DVD any more efficiently? The help menu doesn't really describe why you would use these...only in the context of using a pre-built template menu.
Anyone have any experience with this?
-Jason
Michael Eschbacher
Re: Encore CS2 - button type - why use them? normal - chapter - next - previous - main
on Jun 26, 2008 at 7:07:07 am
By changing the button type you can help yourself out greatly if you are creating chapter menus. If you set up a menu with proper buttons set as chapter, previous, and next, you are able have Encore generate menus for you very quickly. It is quite powerful once you wrap your head around it.
