Incompatible Format
COW Forums : DVD Authoring
Sam Pope
Incompatible Format
on May 7, 2008 at 4:12:13 pm
I need to author a DVD for a short (4 min) project that I put together. I exported the timeline to compressor and compressed it using the HD DVD: H.264 90 minutes setting at 10.3Mbps.
When I try to import it as an asset into DVD Studio Pro it tells me that it's an incompatible format. I know DVD Studio Pro accepts H.264...so what's the problem? I'm supposed to deliver this DVD this afternoon, so any help would be appreciated.
Ryan Valle
Re: Incompatible Format
on May 7, 2008 at 10:05:38 pm
make sure your dvd studio pro project is set to HD-DVD.
- Ryan Valle
Sam Pope
on May 8, 2008 at 12:30:53 am
did that. still no luck. i checked the manual and hd h.264 should be compatible.
i'd prefer to use that and not mpeg..
thanks
John Higgs
on May 8, 2008 at 1:56:40 pm
I import the timeline to create a quicktime movie then into Studio Pro 4 then burn the
HV-DVD TS in Toast9 with HD Plugin onto a good quality standard DVD disc, works a treat.
Sam Pope
on May 8, 2008 at 3:35:11 pm
Okay, but isn't H.264 and Apple codec? Hard to figure out why it would be so hard to bring it DV SP...
John Higgs
on May 9, 2008 at 2:31:44 pm
I had the same problem, i am waiting for a mate of mine to work it out, but as i said i did it
in quicktime with great results.
John Higgs.
PS,
I shoot on HD-Cam, and import to FCP at 10Bt uncompressed, the HD-DVDs are
fantastic.
