Rip from DVD straight to MPEG2 format? (without re-encoding)
COW Forums : DVD Authoring
matt heeley
on Apr 11, 2008 at 10:09:45 am
Hello!
I have some footage on DVD (in .VOB format)
I have been told that .VOB is basically an MPEG2 with extra information...Is there a way to extract the footage and remove the information that makes it .VOB?
I need the footage to be in MPEG2 so i can put it into Adobe Encore with other video files to burn.
I dont want to have to re-encode it as this will cause loss of quality! Is there a way to rip the footage off the DVD into MPEG2 format?
any help would be very very much appreciated!!
cheers
Matt
Lucas Fazzary
Re: Rip from DVD straight to MPEG2 format? (without re-encoding)
on Apr 11, 2008 at 11:18:05 am
There are a number of programs that do this. Are you on MAC or PC? You looking for free, cheap, or pricey demuxer?
matt heeley
on Apr 11, 2008 at 12:05:05 pm
Im running a PC Windows XP Pro.. ideally free or cheap.. would be very handy!! Thanks... what would you suggest?
Lucas Fazzary
on Apr 11, 2008 at 2:54:07 pm
Free:
http://members.cox.net/beyeler/bbmpeg.html
http://www.afterdawn.com/software/video_software/dvd_rippers/smartripper.cf...
http://www.afterdawn.com/software/video_software/video_tools/rejig.cfm
http://www.videohelp.com/tools/VOB2MPG
http://www.videohelp.com/tools/VobEdit
http://www.videohelp.com/tools/DVD_Decrypter
Cheap:
http://www.dvd-logic.com/
I think the DVD-Logic DVD Demux is your best bet and only $40.
The free ones will do just fine also.
I hope this is what you were looking for.
-Luke
matt heeley
on Apr 11, 2008 at 3:30:44 pm
Thankyou very much luke..
i will try these out next week and let you know how i get on!
cheers
Matt
George Wing
on Apr 12, 2008 at 3:35:42 am
Which version of Encore are you using?
Have you tried to just import the VOB?
In the Project window, rt-click / Import As / Timeline / then for file types select ALL FILES, and select the corresponding IFO file -- or the VOB file). This doesn't always work, but might be worth a shot...
Regards,
George
matt heeley
on Apr 14, 2008 at 9:14:36 am
Cheers George i will give that a go!
Im using Encore that came with Adobe Premier Pro CS3 bought just before xmas..
i'll let you know how i get on!
Cheers
Matt
R. D. Hamilton
on Apr 14, 2008 at 5:53:54 pm
I use PGC Demux all the time. It is free, and works perfectly....it doesn't convert or recompress or anything.
-RH
