Motion is stuttering in DVD playback
COW Forums : DVD Authoring
Brian Tetamore
on Mar 13, 2008 at 6:22:04 pm
This is probably related to a ton of posts, and speaks to the challenge of authoring in DVD. Here it goes. I have a video feature, two minutes in length that has sections where there is motion of the graphic elements. The motion is suppose to be smooth as the camera moves in 3D space from one object to the next (After Effects 3D camera).
However, watching the authored DVD you see stuttering in these areas of motion. SO, what compression settings can I use to create an mpeg2 file where this motion will look good, if not like what it should from the original?
I'm using Compressor 3.0.2,
MPEG-2,
Two pass VBR best
bit rate: 6.5Mbps avg and 7.9 Mbps max
Motion Estimation: Best
The Visual Rabbi
Noah Kadner
Re: Motion is stuttering in DVD playback
on Mar 14, 2008 at 3:04:49 pm
try 7.5 instead of 7.9.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
http://www.callboxlive.com
